Post by Yogi B on Sept 29, 2020 14:43:24 GMT -5
As I've mentioned in the past, I've got a new plan for my SHS Strat -- my original plan, now some four years ago, was an exercise in maximising what could be achieved with a 4PDT ON/Z/ON switch and an 8PDT double-megaswitch. Also, as I've previously said that design was never realised: I was never really happy with it, never got as far as ordering the 8P5T, instead filling the hole in my pickguard with a humbucker sized P90 and calling it a day.
So, obviously, I'm now revisiting the idea of putting a humbucker in its place, but before I detail the new plan, I shall discuss what I view as shortcomings of the old design:
So we arrive at my new proposal which strips the available number of pickup combinations to ten, but delegates the choice between 'normal' and 'alternate' settings between three push/push volume pots.
The ideas is to have only ever one volume pot active, controlled via the 5-way switch: bridge volume in position 1; middle volume in positions 2, 3 & 4; and neck volume in position 5.
The push-push portion of each volume control then separately toggles between the modes: bridge p/p in positions 1 & 2; middle p/p in position 3 only; and neck p/p in positions 4 & 5.
The disparity between those two assignments (e.g. middle volume controls pos. 2, 3 & 4, but middle p/p controls only pos. 3) is intentional, as it makes sense to me based on what the actual selections are. Should I later decide that I'd rather have the middle volume control only position 3, then it is a relatively simple change (needing only a few wires to be moved).
The requirement for the 5-way selector switch is six poles. Hopefully this will be achievable by jury rigging two super-switches together, reducing the spacing between the wafers such that I can fit three in the space where two were previously (leaving me with a 6P5T and a spare DP5T), though I will need some appropriate nuts & bolts to replace the rivets that hold a stock super-switch together.
In order from bridge to neck we have: bridge SC (north), middle HB South (screw) coil, middle HB North (slug) coil, and neck SC (south), and the intended switching scheme is as follows:
You'll see that five of the six poles are tied up with the main switching, leaving only one pole to switch the volumes -- not enough properly disconnect the unused volumes, so in all positions all three volumes load the signal in parallel. Though the result isn't so bad: 500k / 3 = 166.6k, a nice middle value between two 500k pots (250k) and two 250k pots (125k) -- in fact, more precisely, it is the harmonic mean: 2 / (1/250k + 1/125k) = 166.6k -- alternatively it could be thought of as a 500k volume paired with a 250k tone.
This along with the main switching could be done better with the two extra poles of a 8P5T, and it might still ultimately come to that, but for now I'm sticking with the 6P5T plan.
Although I'm quite fond of the idea of using blade switches in a more auxiliary role, in this case as the mode switch, that unfortunately relegates the main bridge/middle/neck selection to a 4PDT toggle which don't have the nicest feeling to operate.
Additionally this meant that the fifteen different possible selections were positioned along the 5-way switch in an arbitrary way. Sure, the switches are conceptually easy to understand: a 3-way bridge/middle/neck toggle and a 5-way mode selector. However, the mode switch is too powerful for its own good, despite attempting sort the selections into logical groups and ordering, I doubt that there's enough reasoning relating the adjacent modes in order to intuitively steer my mind to my sought selection. Returning the 5-way switch to a more traditional function would greatly help in this regard, as would reducing the total number of selections.
Following on from that, I have a couple of guitars with a 5-way switch a a two-position 4PDT, giving a total of ten selections. These work well as they are quite easy to comprehend as two sets of five: 'normal' and 'alternate' modes. However, because the mode toggle acts globally and is paired with a master volume and a master tone control, this style of wiring offers no ability to preset a pickup selection and/or volume level accessible through the manipulation of only one switch.
- Bridge volume control active
- Bridge volume push-push down: B × MS
- Bridge volume push-push up: B × (MS + -MN)
- Middle volume control active
- Bridge volume push-push down: B × -MN
- Bridge volume push-push up: B + MS
- Middle volume push-push down: MS × MN
- Middle volume push-push up: B + N
- Neck volume push-push down: N × -MS
- Neck volume push-push up: N + MN
- Neck volume control active
- Neck volume push-push down: N × MN
- Neck volume push-push up: N × (MN + -MS)
