Post by unreg on Dec 3, 2020 22:14:58 GMT -5
So the buddy who advised you to put the two 1 meg resistors on your once 500k tone pot was getting you to that 250k. That extremely helpful guy provided just a list; he, thankfully, let me chose what to use. Read my explanation from earlier in this thread: The genius had gone through a similar situation and so he spent time trying resistors to reduce treble. He provided me a two-column list of resistor values and how they would affect treble. It seemed to me, for some reason, that I needed a resistor that had a value in between two of the list-rows; and after searching, I learned that the resistor value I thought I needed wasnât for sale anywhere I looked. And, I seem to remember finding a wiki page that let me know the searched for value didnât exist. So, I used math and decided Iâd like two resistors. â- frets, thank you so much for helping me to know that the two 1 meg resistors reduce my 500K tone pot to 250K! Itâs extremely fun to know some of the specifics behind my guitar electronics!
Post by unreg on Dec 3, 2020 22:39:36 GMT -5
250K is 250K and it doesnât really matter how you get there. Those resistors ARE altering the taper of that potâs action, so switching to a 250K pot without the resistors would change where on the pot you might find a given âin-betweenâ tone, but it will not change the tone at 10 or at 0. 250K Tone Pots will send more high frequencies to ground... Well, no... The parallel load is the bottom half of a voltage divider whose top half is the pickup. The impedance of the pickup gets bigger at higher frequencies, so that proportionally more of the high frequencies (compared to lower) are dropped across the pickup and therefor less is dropped across ("sensed by") the load. Reducing the bottom resistor makes that divider ratio get smaller at lower frequencies. Nothing is actually "sent to ground". It either completes the circuit or doesn't, and in a lot of ways we can say that it is much harder for high frequencies to do that, because they see a higher total impedance on the way around. But the important part here is the frequency dependent voltage division. Very interesting; thank you ashcatlt!
Post by frets on Dec 4, 2020 12:01:10 GMT -5
Thanks Ash, No one has ever described it to me like that.
Unreg, So where are you with that hum. Is everything good now?
Post by ashcatlt on Dec 4, 2020 15:49:10 GMT -5
Thanks Ash, No one has ever described it to me like that. I find it to be the most useful way to think about how a filter works. âEverything useful is a voltage dividerâ. Figure out what makes the top of the divider and what makes the bottom. Caps get big at low frequencies. Inductors get big at high frequencies. When you start mixing them, things can get complex (like literally complex as in imaginary numbers and vector math) which can lead to resonances and such, but for quick âback of envelopeâ eyeballing, it is a good way to get a general idea of whatâs happening.
Post by blademaster2 on Dec 4, 2020 16:18:57 GMT -5
Thanks Ash, No one has ever described it to me like that. I find it to be the most useful way to think about how a filter works. âEverything useful is a voltage dividerâ. Figure out what makes the top of the divider and what makes the bottom. Caps get big at low frequencies. Inductors get big at high frequencies. When you start mixing them, things can get complex (like literally complex as in imaginary numbers and vector math) which can lead to resonances and such, but for quick âback of envelopeâ eyeballing, it is a good way to get a general idea of whatâs happening. That is a beautiful and simple way to look at it. I think of it that way myself.
Post by unreg on Dec 5, 2020 18:41:07 GMT -5
Unreg, So where are you with that hum. Is everything good now? Where am I with that buzz? Hmmm... last night, I tackled a problem that I rediscovered while looking at the wiring. The problem: The signal wire from my bridge pickup, to my 3-way switch, is a size 30 wire and so VERY thin. I had resoldered that connection after creating the star ground paperclip, and maybe 5 of those strands were loose after the solder point was made... so had I wrapped that part of the exposed wire with electrical tape. That electrical tape did NOT hold and all the wire strands in that thin, size 30 wire, turned black.The solution: So, I trimmed the black wire, restripped, and soldered the nice shiny bridge pu wire to my switch. However, before sleep, I noticed that my melting of that pointâs solder on the ironâs tip caused the solder point to appear yellow. And after listening this morning, it sounded bad - the tone was restrained. So just finished removing that yellow solder and soldering that point again... correctly this time. Now, the guitarâs tone is so full! But, a little of that buzz appears again after turning the vol knob to max. Not solved yet, but definitely much closer than Iâve ever been to a noiseless guitar. âď¸ Iâll keep you updated, but not here as this threadâs problem has already been solved.
