Post by ssstonelover on Jan 14, 2021 1:34:33 GMT -5
I had to work on a Hofner bass guitar and made the following wiring 'tracing' based on the German control circuit I installed on the Ignition version as part of an upgrade. Hofner's circuit is a bit unusual (Solo/Rhythm gives 100%/70% volume for example by removing/adding a 100K resistor in the load) plus the on/off of the pickups is opposite to what the lettering might suggest (pull up toward the body in the playing position for ON is what you need to do). I'm including the control plate and brass shield in the depiction should someone want to make their own from scratch.
obade
Post by obade on Sept 27, 2023 0:59:59 GMT -5
Hello ssstonelover,
Could you reply the dimensions of the switch panel, including the copper plate? I want to make such a switch plate from turloid in the color matching to the pickguard of my old Tellson Guitar.
Thank you.
Peter from Holland.
Post by ssstonelover on Sept 29, 2023 12:19:51 GMT -5
Hello ssstonelover, Could you reply the dimensions of the switch panel, including the copper plate? I want to make such a switch plate from turloid in the color matching to the pickguard of my old Tellson Guitar. Hi Peter, Sorry for the delay, I just saw your message. I had created the image in 1:1 scale fortunately in AI (Adobe Illustrator), and then exported it into PNG so the scale information was lost of course. I still had an AI copy, converted to DXF, then transferred it to SolidWorks and got these dimensions. This should get you close.
