Post by ziggystardust723 on Feb 2, 2021 9:00:12 GMT -5
Hello 'Stratos Addicts', -1Solution cheapper than to by an other Pickup, which could be a little diff' than your's: -1) Have to get 2 Neodymium Magnets, 0n the Web: in Japan or China etc.. Not Expensive: around 10€.. -2) With these 2 Magnets (Ultra Strong: Take very Care: my 2 1st hearted themselves each other & Explosed litterally !.), > you can Change the Polarity of your 0wn Meddle Pickup, + After: you have only to change the 0ut of Each wire of the pu: > in the 0ther Side: = when you're looking the PU, with Wires in front of you: - Black Wire on your Left (which goes to Ground = Beginning of the Coil), > Take it going now to + - & for the Wire on your Right: = White or Yellow (End of Winding, going to + = at the Selector Pickups) > You've to make this 0ne Going to - = To Ground.. (What a Normal pickup may had been fit normaly, but 7ender was afraid than the Wire was in Contact Electrically with the Rods-Magnets: so they were linked in the 0ther Side = gave More Buzz because the + was linked '0utside'.. but there's a Coat around Every Wire = the Wire Copper inside is Never in Contact with the Magnets.. I know: Wind myself since 8y..) > Let's Try it.! = A Better Solution than to Change your Middle Pickup.. > & linked in the 0ther Side: = it will Sounds Better.! Bye Folks, Ziggy (France,15h).
