Post by agentwayward on Feb 22, 2021 6:14:06 GMT -5
I generally adjust the overall pickup height to something like this:
Humbuckers: 1.5mm both sides. Single coils: 2mm bass side, 1.5mm treble side.
I never adjust the pole pieces.
I think I should perhaps pay more attention to this part of the setup.
Does anyone want to suggest a more focussed pickup height adjustment scenario or is it more a case of fiddle until you like the results? Pole piece adjustment? Yay or nay?
This question has come about since I built the HSH strat. I've got a lot more going on here than the usual pickup combos, so it seems worthwhile delving a bit deeper into pickup heights.
Post by ziggystardust723 on Feb 23, 2021 6:07:22 GMT -5
Hello Agentwayward I think the most simple is to use a Single Coil with Screws in place of Rods-Magnets, - As this you can turn the Scews as you listen the Sound, - on a Pickups with Scews & // to the Pickguard, > & after you have just to reproduce the Sides/Highs of Screws on Rods-Magnets, or All the Pu itself.. Bye, Ziggy (France, 12h07)
Post by agentwayward on Feb 23, 2021 7:46:28 GMT -5
So, I tried this method.plugged my amp in to my PC and used a basic DB meter program that was connected to the amp channel.
Some practice was invoved to ensure consistant string picking.
I set the pole pieces on each pickup first, even heights, just proud of the pickup.
I set the overall height of each pickup first, 1.5mm high E string, 2.00 low E string.
I used the low E string as a bass, it turned out to be 50DB.
I set each other pole until each was as close to 50DB as I could reasonably get, allowing for the impossibility of ensuring precisely the same picking strength.
The volume output of each string over both pickups is now even.
I then raised the bridge pickup overall, as I like my bridge to be slight stronger. Rechecked levels and all is good.
Worthwhile exercise? I think so. I
