sysdoc
Post by sysdoc on Mar 22, 2021 12:46:14 GMT -5
Hello everyone! I have an Ibanez S series withe HSH pups, that I was wanting to simulate the Ibanez AZ wiring for. First challenge here is the low-profile 5 way switch that is in the guitar now, the height of the switch from the switch mounting plate can only be 30mm max. I have already tried the Oak Grigsby 5-Way Single Wafer Super Switch, and it will not fit. The diagram below show the usage of the Super Switch and so I need a switch to accomplish this that will fit into the body, any suggestions? Second challenge is modification of the below diagram for a HSH setup. I have an HSS configuration on another ST style guitar, I can fit the Oak Grigsby into I have a Seymour Duncan TB-6 that I'll be adding in the bridge position, that this diagram should work with. Here is the wiring diagram: Thanks in advance for your replies.
Post by newey on Mar 22, 2021 13:40:13 GMT -5
I have an Ibanez S-Series that also has that ultra-thin body. I've never tried fitting a different switch but like you I have my doubts that anything other than the stock switch will fit.
The only other switch that is similar to the Oak Grigsby Superswitch (at least AFAIK) is the EYB/Schaller Megaswitch M . We recently had someone else ask a similar question and as I recall that depth on that switch was roughly the same as the Oak Grigsby.
EDIT- According to the Schaller webpage, the Megaswitch is exactly 30mm deep.
