Post by ziggystardust723 on Apr 13, 2021 10:25:38 GMT -5
Hi all Strato addicts, Making an HB with 2 Strato pu: 1) To change the magnet pulling, Have to Change 1 of the 2 same PU you'd choiced, = with 2 Strongest Magnets, than you can find for cheap on the Net: > 2 Neodymium Magnets,near big like a Straro PU, = You Change the Magnetic field with 1 of these Magnets on the Top of a Strato PU, & the other 1 Under, for some times.. > You Test with a Boussole (in French: that says N or S..) - Then, you Change the wiring of the PU: the Blk Wire (begining of the Coil) > Goes now to + , > & the White Wire (End of the Coil) = Goes now to - - You can wire the 2 PU => & they became 1Humbucker. 'That's all folks'.. > Try it .! + Tell me what you think of result. - Bye, Ziggy (a french guy, living in France near Paris, winding PUs, 66yo)
Post by psiloguitarensis on Nov 21, 2021 13:38:04 GMT -5
thought one had to heat a magnet quite a bit to change its polarities guess not ill have to try this out some time but couldnt you just use a neck and mid pick and wiring parallel?
