Oripure AlNiCo P-90 Neck and Bridge Analysis
Apr 24, 2021 21:45:05 GMT -5
roadtonever and frets like this
Post by antigua on Apr 24, 2021 21:45:05 GMT -5
These Oripure AlNiCo P-90 shaped pickups are are currently $40 a piece on Amazon, which aren't the cheapest pickups among Chinese made pickups, but are still a tiny fraction of what comparable boutique pickups cost, such as a Lollar AlNiCo P-90, at $110 per pickup.
As seen in the pics below, these bobbins are taller than a P-90, more along the lines of a Telecaster bridge pickup. The drawback of a tall, thin coil is that the output is lower when more of the electromagnetically reactive parts are farther from the guitar strings, and the lower permeability of AlNiCo means that less of the string's magnetic field is transmitted to the lower portion of the coil. So it would have been nice if this had thin/wide coils like a P-90, but on the plus side we can appreciate the idea that they're more like a Telecaster pickup.
They sell a "bridge" and a "neck" model, though the neck pickup has an inductance of 3.7 henries, while the bridge version has an inductance of the 6 henries, which is a wider spread than usual for a neck and bridge version of a typical pickup set. Some people might prefer two neck pickups instead, especially if you're looking for a Tele style pickups in a P-90 housing. In fact the bridge pickup has so much more wire on it that it's visibly much wider. While the neck pickup could be a Tele bridge pickup, the bridge's coil is so wide that it would probably not fit a Telecaster bridge bobbin.
Since the steel screws are replaced by less conductive AlNiCo, the Q factor is higher than with a regular P-90, so these might pair better with 250k pots, as Strats are Telecasters do with their AlNiCo poled pickups, and with 500k pots the treble at the resonance might stick out more, but rolling to the tone control back a little would have the same effect as 250k pots.
The AlNiCo pole pieces are said to be AlNiCo 5, and the flux density at the pole tops measured 900G, which is normal for AlNiCo 5 poles of that size and shape. Note that it's a "flat stagger".
They also put shielded copper tape, as well as regular insulation tape around the coil. The capacitance of the bridge started out at 180pF, but with the copper tape disconnected from ground, the capacitance dropped to 112pF, which is equivalent to about two feet of guitar cable. With a 470pF load, that pushed the resonant peak from 2.2kHz up to 2.5khz, that enough to make a slightly audible difference.
The copper take also causes eddy currents, though the effect is not dramatic. Without load, cutting the copper tape increases the amplitude at resonance by 3dB, but with load, the difference is about 1dB, which is barely audible. The good news is that since the coil has both regular tape and copper tape, it's very easy to peel the copper tape off without risking the coil, if you want to remove the tape and have a true Fender style AlNiCo single coil.
The pole pieces of both pickups are 50mm, which has to be taken into consideration since P-90 covers can come in a few different spacings.
The packaging is also very nice. It's probably only a matter of time until they start including a guitar pickup.
I'm planning to install them into a TV yellow Les Paul Special, but I'm not expecting it will sound like a Telecaster, because the pickups are still positioned as a Les Paul and not a Tele. I'm expecting it will sound mostly the same, but brighter and thinner, and that sharper sound you get when you have strong magnetic pull on the strings.
OriPure Solid Sound Soap Bar Pickups P90 Bridge
- DC Resistance: 9.370K ohms
- Q @1khz: 3.11
- Measured L: 6.164H
- Calculated C: 180pF (112pF with shielding disconnected)
- Gauss: 900G (AlNiCo 5)
OriPure Solid Sound Soap Bar Pickups P90 Neck
- DC Resistance: 7.013K ohms
- Q @1khz: 2.73
- Measured L: 3.7128H
- Calculated C: 217pF
Bridge unloaded: dV: 9.4dB f: 5.57kHz (black)
Bridge loaded (200k & 470pF): dV: 3.5dB f: 2.23kHz (blue)
without shield, unloaded: dV:11.5dB f: 6.14kHz (black)
without shield, loaded: dV: 4.1dB f: 2.5kHz (blue)
Neck unloaded: dV: 9.6dB f: 5.48kHz (red)
Neck loaded (200k & 470pF): dV: 4.1dB f: 2.89kHz (green)
The bridge pickup, with and without the copper shield tape:
