Post by frets on May 13, 2021 14:18:34 GMT -5
Hi Guys😸😸😸, If you recall, I was all twitterpated over a pcb board that was to go on a screwless terminal to make a plug and play harness. It turned out that the board was fine. I moved it over to another harness and it worked great. So now I can install harnesses in my guitars whereby a guy can quickly change out his pickups. I’ve got the ground to the terminal running from the corner inside of the switch. Weeeeee!!
Post by unreg on May 13, 2021 14:34:42 GMT -5
frets, so happy you have been triumphant in your quest! 😀 Now people can quickly change pickups; though, sometimes (often?) wiring is adjusted inside a guitar relative to how the pickup sounds, at least in my case. Hope your effort to help is super successful mam! 👍
Post by b4nj0 on May 14, 2021 5:34:14 GMT -5
That's a great result C, but how did you resolve the conundrum regarding the tags and inputs on the connector? was it just down to that "ground" connection as in no signal return path?
Beautiful wiring. Such short conductors with (what looks like?) push-back cloth wire is really impressive to me at least. Reminds me generally of the aircraft galley control module wiring at my last place of work. You'll be lacing too before long!
e&oe ...
Post by frets on May 14, 2021 12:06:11 GMT -5
Hi B4nj0 😻,
Thank you!! I still don’t know what was wrong with the first harness I attached it to. I must have had the ground wrong, that’s all I can figure
Hi Unreg😻,
Thank you too!
Post by unreg on May 18, 2021 1:35:25 GMT -5
You’re welcome! 👍🙂
