Post by Greg Holmberg on May 27, 2021 22:44:08 GMT -5
Last year I began a journey to understand guitar pickups. I read some of Helmuth Lemme's articles, and was surprised to learn that they can mostly be described by their frequency response, which is a fairly simple curve (very different from the frequency response of an acoustic guitar, for example).
Of course, no manufacturer publishes the frequency response of their pickups, which is disappointing, since it makes it difficult to compare pickups. This leads to a situation in which guitar players describe pickups in subjective terms, much like wine drinkers. There's almost no way to know if you would like one before you buy it.
This leads the life-long "tone quest" many guitar players find themselves on. They buy and sell many products trying to find the magic combination. Pickups, overdrive pedals, guitar amps, guitar speakers. Many never come to the magic pot of gold at the end of the rainbow. They just keep buying products forever. This is great for the manufacturers, not so great for the players. It's clear why it's not in the pickup maker's best interest to publish the frequency responses of their products.
So I ask myself, what is really happening when a guitar player is trying out these combinations of products? Although there are several effects going on, I think the main one is the superposition of the frequency responses of the pickups, the pre-amp circuit, the guitar speaker, etc. Each has it's own unique frequency curve, and when you combine them you get a net frequency response that is interesting.
So, essentially, when players try different combinations, they're just taking devices with hard-coded EQ settings and combining them, hoping for something good. The same result could of course be achieved with EQ devices that are more flexible. Instead of buying hundreds of products over your lifetime, you could just buy a multi-parametric EQ and get all the frequency responses. You could easily measure known good tones with a microphone, audio interface, and a computer, and then set the parametric EQ to match.
Now, I could try to do this today with a pickup with a known frequency curve, and add/subtract from that to get what I want. However, this becomes a bit difficult with the large resonance peaks of many pickups, and then it becomes impossible when the pickup completely cuts off signal above a certain frequency.
It would be a lot easier if I had a pickup that has a flat frequency response, at least up to the highest frequency I care about. I could then feed that into my computer and use software EQ to get any tone I want. I learned from Helmuth's articles that a pickup's resonant frequency can be pushed up outside the range of human hearing, leaving a flat response in the range I care about. He called it a "low impedance" pickup, and it had already been done by Les Paul in the 1960's.
Les Paul's "Recording" Guitar (another interesting article by Helmuth) had a very low impedance pickup, with an inductance of 0.008 Henries and a resonance peak over 200 kHz! EQ was in hardware not software (his "decade" switch of capacitors), but basically the same idea. A guitar that can mimic any other guitar because it starts out neutral. Here are some recordings Les Paul made with the guitar demonstrating the different tones: side A, side B.
So I had Helmuth build me such a pickup. Here it is:
Design: humbucking using two half-width coils—a “split” pickup as in a Fender Precision Bass or the G&L Z-Coil guitar pickup. Single point of sensing, so as not to lose or distort certain frequencies.
Balanced output (three wires) to reduce noise in the cable. Isolated from ground. Can be used unbalanced (two wires) also.
Dimensions: 70 x 38 x 12 mm, 2.75 x 1.50 x 0.50 inches.
Cover: black plastic. Copper shielding inside.
Mount: end of fretboard.
Space to strings: 3 mm recommended.
AC inductance: 0.3 Henries.
DC resistance: 1.6 kΩ.
Output voltage: 15-20 mVRMS = 21-28 mVPK.
This is not intended to be used directly into a guitar amp. It would require a pre-amp to change both the voltage and the impedance. I wired it to an XLR jack (balanced), and I connect it to an audio interface (microphone input). I connect that to an iPad and add EQ and other effects using the BIAS FX 2 software from Positive Grid, and play through full-range studio monitors to get those higher frequencies.
I tested this pickup with Ken Willmott's Integrator device, a MOTU M2 audio interface into a Mac, using the Room EQ Wizard software.
Minimum load in red (10 MΩ, 10 pF): 15.44 dB @ 17.0 kHz.
Load in green (200 kΩ, 470 pF): 12.07 dB @ 10.26 kHz.
Inductance test in blue (10 MΩ, 4700 pF): 4270 Hz.
As you can see, the resonant frequency is very high, and in the range of my hearing (about 13 kHz--I'm old!), it's essentially flat.
In the following recording, the pickup is installed in an inexpensive fully hollow archtop (laminated top, strings are D'Addario Half Rounds, 10-46), at the end of the fretboard, and then wired directly to the audio interface (no tone or volume controls), into an iPad and recorded with Garage Band. No EQ, compression, reverb, or any other effects were added. You can hear that it's a very quiet pickup--no hum at all. There are eight segments, the first five are played with a pick, and the last three are played with fingers. I pick up near the neck, never down by the bridge. Mistakes were made, but I think you can get an idea of the tone.
JZ2 recording
By itself, it sounds uninteresting--kind of like a boring acoustic guitar. Even beyond an acoustic guitar, which ends at about 12 kHz.
But it's a great starting point for manipulating into different shapes. The "Guitar Match" feature in BIAS FX 2 seems to do a pretty good job with this pickup applying EQ adjustments to mimic certain pickups. Alternatively, I can easily cut off frequencies above various levels, and add a hump at a certain point, and get a variety of common tones. Personally, I prefer a clean Jazz tone like a P-90, and I can get that by cutting off above 4 kHz and boosting the 2-3 kHz range. Maybe boost a little in the bass around 100 Hz. However, if I want to sound like an acoustic guitar, the frequencies have not been lost, and with a few adjustments, I can have that sound too.
Helmuth also tested the pickup. His tester has a minimum load capacitance of 47 pF plus some unknown amount from a 30 cm cable. The first two graphs show the JZ2 tested with a 300 kΩ resistor and various capacitors:
The third graph shows the JZ2 tested with no additional capacitors (so 47 pF), but various resistors:
So, collecting all the data from both tests:
What I find interesting about these graphs is that one could move the resonant peak down to almost any frequency one wanted with the right capacitor (as Les Paul did), and one can lower the peak dB with the right resistor.
I think you could have a single guitar that could mimic most pickups by applying a set of resistors and capacitors to the pickup. Combine that with a pre-amp that has a shelving-style treble and bass controls (Baxandall), and converts the voltage and impedance to something a guitar amp wants, and you have a guitar that can sound like any other guitar.
I'm surprised that some guitar electronics vendor out there hasn't already done this, but then again, it might spell the end of the "tone quest", and that's not good for business!
JZ2 recording
Position | Additional capacitance pF |
11 | 0 |
10 | 470 |
9 | 1000 |
8 | 2200 |
7 | 3300 |
6 | 4700 |
5 | 6800 |
4 | 10000 |
3 | 15000 |
2 | 22000 |
1 | 33000 |
