cem
Post by cem on Jan 27, 2022 6:09:12 GMT -5
It is possible that the lugs on the superswitch for poles c and d run in the opposite direction to Newey's diagram. If you look, the diagram has A and B running 1/2/3/4/5 from left to right and C and D running 5/4/3/2/1. However, on some superswitches at least all the lugs run in the same direction. So C and D would run 1/2/3/4/5 left to right, just like A and B. I suggest asking your guitar tech to test whether the Neck pickup is coming on in the Bridge and Bridge + Middle positions, and whether the Neck + Middle position is actually only the Middle. If so, then that is what has happened. It needs to be connected to the three lugs at the other end instead. This is exactly why it didn't work. Thanks again to everyone that helped. The guitar sounds much more balanced now outputwise and its just the way i like it
Post by jhng on Jan 27, 2022 10:17:13 GMT -5
Glad to hear that you got it all sorted out.
