Post by tomislavperanic on Nov 9, 2021 14:22:52 GMT -5
Hi, would you be so good if someone made the following guitar scheme? i have a SuhrV60lp and a Dsv Suhr bridge magnet. I would like to connect a mini toggle switch with a CTS tone push pull potentiometer.
Post by unreg on Nov 9, 2021 15:22:59 GMT -5
Hi, would you be so good if someone made the following guitar scheme? i have a SuhrV60lp and a Dsv Suhr bridge magnet. I would like to connect a mini toggle switch with a CTS tone push pull potentiometer. Welcome tomislavperanic! 🎂🙂 So, you have a single coil and a humbucker pickup and a mini toggle switch; and you want to only connect a tone push/pull pot? No volume adjustment pot? Why use a complex p/p pot? 8-0 What is the push pull meant to do?
Post by newey on Nov 9, 2021 16:42:06 GMT -5
Yes, we're going to need some more information. You describe this as a SSH guitar, but then you only list 2 pickups, a Suhr V60LP single coil and a DSV humbucker for the bridge. Is the 3rd pickup also a Suhr, or something else?
As unreg asked, what is it you want the mini-toggle and push/pull pot to do? Is this a Strat-type guitar with the standard 5-way lever switch to switch between pickups? How is it wired now? In particular, is the bridge HB that is in there now currently split to single coil at position 2 of the 5-way switch (This is the usual way Fender wires their SSH Strats, but you didn't specify what type of guitar you have).
Post by Deleted on Nov 10, 2021 4:15:41 GMT -5
Maybe easier if we have a system in place, Flow Chart. Done they do that on Seymour Duncan site for their designs... -------------- So Single Coil, Humbucker, Toggle Switch with a Push Pull Pot (i dont care for brand names CTR Suhr its up to you what you want) Well with more switch could FAKE a HSS with a HS 1) Neck, 2)Neck+North, 3) North, 4)Neck+Humbucker, 5) Humbucker On a budget with a cheap S-Type Strat Switch £1.50 Max Maybe a Push/Pull or Toggle to Flip the Coil of the NORTH bridge to give it a real feel of MIDDLE pickup because its normally phased. Think could work that in to the 5 way switching if used a posher switch 4P5T etc. Toggle (just a switch with a knob on the end to flick) 2P2T (On/On) (On/Off) (On/Off/On) (On/On/On) then you got how many Poles you get one Toggle wit a 6T so a Push Pull Pot, Just volume or Just Tone and what to do with this 2P2T push pull, Split the Humbucker, coil flip! I used to get things like this when building Computers, But once you tell them the cost of such a thing they aske for the 2nd best .. so on .. till how much you want to spend
