Chman
Post by Chman on Dec 7, 2021 15:07:18 GMT -5
I'm looking for a delay pedal with similar time delays as an old Watkins CopyCat.
If you don't remember these they were a tape loop echo unit with one record head
plus three individually selectable replay heads spaced about 150 mS apart. The good thing was that you could select the second and third playback heads without the first one.
So the echo would be ORIGINAL -delay of 300mS- FIRST ECHO - delay of a further 150mS - SECOND ECHO. These were then fed back to repeat and gave a very realistic echo. The echo effect would be | || || || fading away.
So, are there any pedals which can be set to produce this type of delay?
Post by newey on Dec 7, 2021 16:53:43 GMT -5
chman-
Hello and Welcome to G-Nutz2!
Sorry, I don't know of any pedals that clone the Watkins Copicat. A quick search found a bunch of VST plug-ins to emulate that unit, but no hardware.
Someone else may be along with a suggestion for you. I've never even seen a real Copicat, much less played through one, so I don't know much about it. My first thought was that (I think) the Roland Space Echo had multiple playback heads as well, and I know Boss makes a digital pedal to clone the Space Echo (Boss RE-20), but I don't know whether that was similar to the Watkins 3-head system you describe.
Post by gckelloch on Dec 7, 2021 17:54:58 GMT -5
Chman
Post by Chman on Dec 9, 2021 10:57:20 GMT -5
Thanks gckelloch that looks like it would be the job. I would need to find a UK supplier since the Donner advert says "We only ship to USA." I'll try to find one because I have seen adverts for Donner poping up on FaceBook.
Thanks for your assistance and to newey also.
EDIT: Found it on the Donner UK website.....
Unfortunately out of stock, but I've left them my email, so they can inform me when it's back in stock.
Chman
Post by Chman on Jan 26, 2022 11:28:09 GMT -5
I manged to find the Donner White Tape Stereo Delay suggested by gckelloch on the US Amazon
web site and with zero reponse from UK/EU Donner, I ordered it from the US.
It has now arrived and does the job just fine. I can set two different delays for the stereo channels. One mono input feeds left and right channels without any mods but I had to combine the two outputs
to feed one amp (no biggy).
It does exactly what I wanted...... now it's time to let my 60s Watkins Copycat have a well earned rest Thanks again.
Post by gckelloch on Jan 26, 2022 14:58:41 GMT -5
Great news. You sure the L (mono) out doesn't combine both delays when there's nothing plugged into the R out? It usually does in effects like that.
Post by thetragichero on Jan 27, 2022 8:48:05 GMT -5
now it's time to let my 60s Watkins Copycat have a well earned rest Thanks again. betcha it could bring back a decent return on a site like reverb. folks seem to snatch that type of thing up.
Chman
Post by Chman on Jan 27, 2022 11:06:32 GMT -5
gckellochThanks for the suggestion but tried it again and the unit is only prepared to supply the two outputs (L & R). But like I said no biggy, I just combined the signals using a couple
of resistors inside a jack plug.
Chman
Post by Chman on Jan 27, 2022 13:37:56 GMT -5
now it's time to let my 60s Watkins Copycat have a well earned rest Thanks again. betcha it could bring back a decent return on a site like reverb. folks seem to snatch that type of thing up. Yep, I probably could plus a have a 60s AC30 TB as well that I don't use. One day....... perhaps
