Post by frets on Apr 16, 2022 14:12:46 GMT -5
I just heard that the new Revstar model has a newer tone control that replaced the dry switch. It supposedly has a transformer on it. Has anyone seen a schematic for it or have any information? I hear it gives a real jazzy tone?.
Post by Deleted on Apr 17, 2022 5:08:39 GMT -5
Looks intresting Doesnt look like they are using the 2nd Wafer of the 4P5T! cant really see the Links in the 5way switch i see some capacitors two of VEC4100 G AC1 M86RFA So you have YELLOW that seems to be going between the Transformer and the DOWN Position of the Switch BLUE that seems to be soldered to the side of the Push/Pull RED that goes to the other side of the DOWN Position of the Push/Pull Switch and BLACK that seems to go to the same point as the BLUE ie GROUND on the Push/Pull a Capacitor i know is on the YELLOW but im not sure if touching the red!
Post by frets on Apr 17, 2022 7:50:33 GMT -5
That’s a big honking transformer! Thanks Angellahash!
Post by Deleted on Apr 17, 2022 8:11:27 GMT -5
with the transformer like it is .. you are going to be picking up energy from the other pickup i would like to know what each of the positions are and maybe guess from half of the guitar before guessing what the transformer is doing and how its work i am confused when he says "Single Pick up out of Phase" !! in Position 4 from what im hearing on YOUTUBES it sounds like Position 4 and 2 have a Capacitor 1) Neck 2) Neck + (Cap x Bridge) 3) Neck + Bridge 4) (Cap x Neck) + Bridge 5) Bridge trying to see if any thing else Yamaha have Dry Switch----------------------------- Neck Hot goes to the Common on one side and the Bridge Hot goes to the Common on the other side Wire as a Humbucker with no Split 2nd and 4th Positions are linked to the 3rd Positions with a Capacitor on each side and then this runs off to a WHITE Cable that goes to the Treble This is where it gets LOST in the photo Do know the the Two Sides Yellow/Red of the Transformer go to the 2P2T Push/Pull and the other Sides Black/Blue go to GROUND --------------------------------- The Volume seems to have some kind of bleed, i think i can see a Resister but that is about it -------------------------------- At a Guess how it is
