Post by frets on May 20, 2022 15:35:48 GMT -5
Hi Guys, Sometime ago, I asked for help with an HH harness design on which I wanted to accomplish dual coil splits on the volume, and series on the push pull tone pot. I received some help on the forum and have finally gotten around to building it. It partially works and I need some eyes to see if what I wish to accomplish is possible. In the original solution as seen in the first diagram, SW2 when pulled up was to provide B+N in all three SW3 positions. It does so; however, when the push pull is in the down position, the Bridge cuts out both in the B position and the Neck position. I tried a quick “patch” as illustrated in diagram 1; whereby, I ran the red wire from the tone pot to the switch. That attempt does give me the Bridge in the down position in both the B and B+N SW3 positions; but, when pulled up, I lose the B+N series in SW3 B+N position. In B or N when pulled up in their respective SW3 positions, those pickups go into series but not together in SW3 B+N position. I am thinking there is no solution to the problem but I wanted to have done other eyes on it. Again, Diagram 2 gives no Bridge position at all when SW2 is in the down position. Diagram 1 provides the B and B+N positions when SW2 is down, gives B or N series, but fails to give a B+N series. I accidentally reversed them, you know me. I am hoping someone will see the problem. The goal is to have a B+N Series if possible.
Post by Yogi B on May 20, 2022 23:01:37 GMT -5
The modified snippet below should see you right:
Post by unreg on May 21, 2022 1:43:43 GMT -5
When comparing your Diagram2 and Yogi’s fix:
1.) SW3: yellow wire removed, purple wire added
2.) SW2: yellow wire removed, bridge pup’s black wire is extended and connected again, new purple wire connected to lug2, dark blue and dark green wires swapped
3.) SW1: dark green wire moved and connected
Post by frets on May 21, 2022 9:37:30 GMT -5
Thank you Yogi for fixing this issue. I really appreciate it. Thank you Unreg for walking through the fix.
