Humbucker base plates and eddy currents
Jan 7, 2017 21:19:15 GMT -5
gckelloch, mikecg, and 2 more like this
Post by antigua on Jan 7, 2017 21:19:15 GMT -5
A few months ago I compared a Donlis humbucker, a low cost PAF style pickup from China, with a DiMarzio 36th Anniversary PAF pickup.
The Donlis did no contain a metal cover, which is probably a good thing, considering that it would likely have been made of brass, and performed unfavorably compared to the nickel silver cover of the DiMarzio, but every PAF knock off has to have a base plate, and it happens to be that most costly domestic humbuckers have nickel silver baseplates, while import humbuckers have brass, and sometimes even aluminum, base plates. So the question becomes; how much is of a difference is made, on a technical level, when the base plate is nickel silver, brass or aluminum?
In the Donlis v. DiMarzio analysis, it appeared that the difference was about 0.4dB and 150Hz at the unloaded resonant peak. Since the implications apply to nearly all PAF knockoffs and clones, I decided to do this test again with a greater amount of care.
I have four pickups with base plates to be compared:
top: DiMarzio PAF Master neck (nickel silver), "HMV" Chinese humbucker (aluminum)
bottom: Seymour Duncan PG+(nickel silver), Donlis humbucker (brass)
The backs... I removed the black paint from a leg of the PG+ in order to verify that it was nickel silver. The PAF Master and the Seymour Duncan PG+ are nickel silver, while the Donlis at top right is brass, and the no-name at bottom right is aluminum. (I accidentally reversed the Donlis and the HMV in the two photo, my apologies)
Since it's impractical to solder to aluminum, the MVH humbucker has an eyelet at the corner for the ground connection:
I've removed the base plates (DiMarzio PAF Master, Seymour Duncan PG+, Donlis, HMV):
For the test, the Seymour Duncan Pearly Gates Plus is the common electronics. The other base plates are attached to it, and then measured.
First up, this is how the compare with no additional load, with common amplitudes up to 400Hz, which roughly correspond to the fundamental frequency of a "G4", or the 3rd fret of the high E.
Each division is one 1 dBV. In audio, it's said that 1dB is the smallest change in pressure that the human ear can detect. You can hear the difference in dB levels for yourself here www.audiocheck.net/blindtests_level.php?lvl=1
The four lines represent the frequency response of the four humbuckers. It can be seen that, while there is evidence off higher eddy current losses beyond 1kHz (the plot lines dip down), the deviation between all of them is less than 1dB:
However, then a pickup is in a guitar, it's "loaded". For test loading I've used 470pF parallel capacitance to represent a guitar cable, and 200k ohms in parallel to stand in for guitar pots. The plot with these values becomes:
The wider deviation seen between 2kHz and 3kHz in the "unloaded" plot carry down almost exactly to the "loaded" plot, where the resonance becomes ~2.8kHz. The widest spread is no more than 0.6dB.
This data suggests that the eddy current losses caused by both the brass and aluminum base plates have no audible effect on the pickup. They will sound too similar for a person to distinguish one from the other.
So if you're in the market for humbuckers and are considering import models, the base plate metal ought not weight heavily in your purchase decision, though if the humbucker as a metal cover, there's a good chance it's brass, and it will cause losses of 3db to 4dB at the resonance, destroying the Q factor.
Another interesting thing to note is that the nickel silver yields a slightly lower resonant peak than the brass and alumnimum, meaning the latter slightly decrease the inductance of the pickup.
Another data point, just for fun, this is what happens when the base plate is removed all together:
The unloaded peak shows a modest drop of 1.2dB, but the loaded peak only drops 0.2dB. This echoes the well known fact that nickel silver is superior to brass and aluminum with respect to eddy currents, but given that none of the differences exceed 1dB, it's all academic in the case of a base plate.
Here is a picture of the test setup. The driver coil that feeds a changing magnetic field to the pickup is taped to the top of the PG+ securely so that it's sure not to move when the different base plates are attached and detached. The pickup is connected to an integrator designed and built by Ken Willmott that removes the +6dB/oct inductive voltage, and the it's fed into a VEllemen PSCGU250 which has a built in function generator to feed the driver coil and produce a bode plot.
