Post by unreg on Oct 7, 2021 11:06:47 GMT -5
Hi 🙂
This is excellent! 😀❤️
While I have no patience to sus out the pickup inter-mingling aboot in your 5-way switch (both poles have shorting effects as well as pickup selection effects), I would suggest that this be done.
For a short-cut way of "seeing" what is amiss and a'muck, I would propose that you replace each pickup with a binary multiple fixed resistor.
Bridge 1 K Ohms (two 2 K Ohms in parallel)
Middle 2K Ohms (one 2 K Ohms)
Neck 4 K Ohms (two 2 K Ohms in series)
This can be realized with 5 resistors, coincidently the number in a pack of 5 from Radio Shack.
Buy 1% resistors if you can.
One can then easily determine the inter-pickup wiring structure from simple resistance measurements at the output jack. Ensure that the volume and tone pots are all at their full clockwise rotation.
Two (or more) resistances in series add, two (or more) resistances in parallel are related like this; Series and Parallel Components.
I do this to initially check out EVERY wiring effort that I do. Simple is.
Ok, now pay attention.
Buy 1% resistors if you can. Buy nothing worse than 5% tolerance resistors.
Solder two 2 K resistors in parallel and connect them where the bridge pickup's two wires went (remove the bridge pickups wires from the switching circuit).
Solder one 2 K resistor to where the middle pickup's two wires went (remove the middle pickups wires from the switching circuit).
Solder two 2 K resistors in series and connect them where the neck pickup's two wires went (remove the neck pickups wires from the switching circuit).
If you measure 6 K Ohms at the output jack, the middle and neck pickups are in series. If you measure 1K33 Ohms at the output jack, the middle and neck pickups are in parallel.
One can easily determine which pickups are selected, and in what structure with this test approach.
If you measure the resistance at the output jack with all volume and tone pots at full clockwise rotation and post the readings, we can trivially ascertain which pickups are selected, and in what structure.
EDIT: is from this thread:
guitarnuts2.proboards.com/thread/4430/wiring-help?page=2#post-39552
General ?: How are resistors wired in parallel? Series is just one connected to the other (in a line) right?
While one can tell if a pickup is active by pole tapping, one cannot tell the inter-pickup wiring structure.
Methinks I may be out of my league 'cause I really don't understand how to do what you've outlined.
I'm considering just trying the standard strat wiring, just to see if I can get that to work.
