Post by frets on Apr 12, 2021 20:36:00 GMT -5
Nchstp, I would advise not using cloth wire for the setup. Much easier to color code it.
nichstp
Post by nichstp on Apr 13, 2021 10:47:10 GMT -5
I ended up getting a custom built set of pups so I won't need to implement a volume switch after all. Just the pots!
Thank you!
nichstp
Post by nichstp on Apr 13, 2021 10:59:20 GMT -5
Damn, I was going to use cloth. Maybe not so much anymore. Nchstp, I would advise not using cloth wire for the setup. Much easier to color code it.
Post by frets on Apr 13, 2021 12:12:51 GMT -5
Hey Nichstp😸😸,
I wire everyday and I think I would go mad if I had to use cloth wire on that particular wiring. Once again, (I talk about this a lot), silicone wire works great because it does not burn.
yatska
Post by yatska on Oct 27, 2023 1:50:28 GMT -5
Hey everybody,
So i'm making a guitar inspired by the red special and also wanted to get in on this added functionality, but with simplified controls.
I was thinking of having a pickup bladeswitch selector and then a push-push pot for getting all pickup combinations instead of individual switches.
And then I'd have 6 switches for in/out of phase and series/parallel.
Would this work?
Post by newey on Oct 27, 2023 6:16:53 GMT -5
yatska- Hello and Welcome to G-Nutz2!Will the Bladeswitch be the pickup selector? And, will it select pickups like on a Stratocaster or in some other configuration? 5-way Switch? Have you already purchased the switches you are describing? We're going to need more specifics before that question can be answered. With the switching you're describing. there could be many possible schemes that would work, and many others that might not. In fact, you may not need all those switches to do what you want to do. But again, more detail of your "wish list" is needed.
