Post by frets on Oct 3, 2023 12:12:09 GMT -5
I don’t think the resistor does much on anything in the circuit.
I am perplexed by your lack of hearing the impact of a 15H inductor/transformer. I can hear the effect with a 1.0H. I have used a 10H transformer and it was too much.
I know I’m not being too helpful but I’m wondering if you have it wired correctly. The reason I say that is because the induction effect is so clear.
I make a pedal Varitone that has a 3-Way induction switch. It has no induction, induction at 1.5H; or, induction at 2.6H. Both induction settings are clearly audible in comparison to no induction.
So, maybe you have something awry in the circuit? Tgat 15H transformer should be very distinctive. Is the transformer good?
sapristi
Post by sapristi on Oct 6, 2023 4:46:44 GMT -5
Hi and thanks for getting back ! So in the meantime I've checked the circuit (nothing seemed out of order) and checked the inductor (15H indeed). I replaced the switch with a pair of alligator clips to swap caps around more easily, and I replaced the 100K resistor with a 1M linear pot (lugs 2 and 3, with 1 going to ground). I'm very happy to say the results are good!! I started with the pot fully clockwise, then turned it back. As I did so the filter vowel got more pronounced, but the volume ended up dipping down too, eventually losing all signal when turning the pot all the way down. So I ended up finding a good "compromise spot" about 3/4 clockwise and I'm probably gonna change it to a trimpot when getting it into the guitar. Either that or keeping the pot on the guitar to control the Varitone's intensity, but gotta keep in mind that it would require switching the lugs around (makes more sense IMO to have CW=more effect) and the knob would have a pretty narrow range of acceptable settings. Not ruling it out, I don't mind it being weird as it's gonna be my own guitar. Interested to hear your thoughts! I still don't see how the original circuit didn't work with 100K though - I might indeed have had some kind of problem that I accidentally solved when changing it
