Post by JohnH on Aug 15, 2020 15:49:13 GMT -5
Hi frets, I think you're posting mainly for tragichero, but can we join in?
I quite like the diagram style, big and clear. By putting pictures of the controls around the pickups, wire runs get teased apart so they can be seen and followed easily in a complex wiring. Obviously it looks not much like an LP control cavity. How would you find working off this for a build? I reckon I'd do it, better than just an electronic schematic if I didn't have a wiring diagram. I think a beginner might struggle but then they probably shouldn't be doing JP wirings anyway.
The circuit itself works out to be mostly what the original versions of this scheme were from Gibson, and which we generally find upon the 'net. Do you build these for clients? and if so how do you/they like them?
A few of us got way deep into the building of better JP mousetraps (or rats nests) 10 to 15 years ago, to try to take out the 'hairs' that this type of wiring has. Here are the things we thought needed dealing with:
This design shows 'independent' wiring, with output from outer volume lugs. It doesn't work consistently and tends to dull the tones a lot. Its intended to help with mixing pickups, and avoids turning the whole guitar off if one knob is at zero, but its not good at mixing. Normal pot wiring is preferred by most of us
Going to series mode, only one volume knob works, and there is no mixing. It is possible to keep the volumes independent, so that in series mode, you can have full of one and a little of the other, and this does work well. This also takes load off giving clearer tone and at the same time, tones pots become properly independent
Also on series mode, you have to put the toggle to select the neck as well as pull the pot. It is possible to have it so that the pulling of the knob forces series mode to work independent of where the toggle is
When you coil cut both, the diagram cuts to different coils on each, all good for humcancelling (should identify that Seymour Duncan coils have been drawn). But if you also pull phase, it will hum. It doesnt need to, we can make that mode non-humming too.
Coil cutting by shunting to ground like this has obviously been done a zillion times and it works, but it saps a little energy and slightly dulls the tone of the remaining coil, which is still magnetically coupled to it. We suspected this then and many years later Antigua proved it in pickup tests. The JP wiring can be arranged to avoid this.
If you build these for clients, and would like these issues addressed, we have schemes.
