drepo
Post by drepo on Aug 5, 2021 17:19:36 GMT -5
I've created a document regarding a Jazz series/parallel mod I've been trying to figure out. I'm new into wiring and I though of getting some help before doing anything stupid, the pdf describes it all, I believe (it contains the jpg and an explanation), but any question and/or help is well received! Cheers and thank you for your time!
Post by Deleted on Aug 6, 2021 0:53:46 GMT -5
Up Neck/hum/hum Down Neck/Both/Bridge
That is if im reading it right Big point is to know the common is on this switch (normally the middle) but four pins
drepo
Post by drepo on Aug 6, 2021 11:15:33 GMT -5
Thank you for having a check on it )
Post by reTrEaD on Aug 7, 2021 10:01:31 GMT -5
Hi drepoThere appear to be errors in your wiring. Because this is essentially a duplication of what you presented in another thread, I'll lock this one and suggest anyone interested should go to that other thread. If you have a valid reason why this thread should stay open, feel free to PM newey, JohnH, Yogi B, or me and one of us can unlock this. Need help wiring a series/parallel switch
